Video plays back dark when imported from SW to Media100i
COW Forums : Media 100
hbvideo
on Nov 28, 2006 at 6:00:50 pm
Before I started using Media100SW on a G5 Quad I could export video as Media 100 NTSC-720 and it would playback fine in Media 100i but now exports are about 25% too dark but look fine while editing. I digitized the video in Media 100i. Also where ever I haven't inserted a black clip on the clean timeline, I get a Blue background. I tried using the Media 100i compressor in Media 100SW but I get the same result -too dark. Tried exporting bars from SW installed on the G4 (different copy of SW 10.2.1) Media 100i compressor. result:same blue background and dark video through Media 100i.
Is this a Media 100i card issue?
G5 Quad QT 7.1.2 Media 100SW 10.2.1
G4 Dual 500 QT 6.5.1 Media 100i/xr 8.2.3 (a?) Copyright 1993-2006 Boris FX Inc. SW 10.2.1
HB
Floh
Re: Video plays back dark when imported from SW to Media100i
by
on Nov 28, 2006 at 6:27:37 pm
How do you export? As "Self Contained"? Or as a QuickTime file with Media 100 i codec? There was an issue with video levels when using the QuickTime export in 10.1.x and 10.2.x; you should upgrade to V11.5 of Media 100 sw/Producer and try the export again. Anyway, when exporting as Self contained you should see no color and luma shift regardingless of which version you use.
hbvideo
on Nov 28, 2006 at 7:35:08 pm
"How do you export? As "Self Contained"? Or as a QuickTime file with Media 100 i codec?
I export as a quicktime file with the media 100i codec.
I bet Producer is the answer...maybe it handles "color range" better ;->
Thanks once again Floh
HB
Floh
by
on Nov 28, 2006 at 7:37:14 pm
Export as "Self Contained" (assuming that you have everything in the Media 100 i codec). This should give better quality (no recompression), it should be faster and it should not change the color/levels.
hbvideo
on Nov 28, 2006 at 10:05:14 pm
"Export as "Self Contained" (assuming that you have everything in the Media 100 i codec). This should give better quality (no recompression), it should be faster and it should not change the color/levels."
OK but the import into Media 100i takes more than an hour...
Floh
by
on Nov 28, 2006 at 10:08:53 pm
[hbvideo] "OK but the import into Media 100i takes more than an hour..."
You should avoid "gaps" in your timeline. As far as I know this "slow import" into Media 100 i only happens if the timeline you are exporting contains empty areas, which are exported in a clever way to save space, but they mean a slow import for Media 100 i systems. If you have spaces in your timeline where you need black, do yourself a favor and take a black Pict, import it into Media 100 and place it there. Maybe using a "black clip" created in Media 100 does work also, but I have to admit that I did not try it.
Floh
hbvideo
on Nov 28, 2006 at 10:59:39 pm
OK, I went ahead and got Producer and happily and thankfully its color range adjustment made the exports via Quicktime show up properly and only take 4 minutes to import. Using the media 100 HD uncompressed gave good quality too. Thanks for the tips Floh!
HB
