setting up a raid Media 100 Hde
COW Forums : Media 100
Greg
by
on Nov 5, 2006 at 8:02:20 pm
I'm putting together my new Hde system. I installed a host card into my mac, and attached the sata drives with their enclosure. I will be ataching an additional SATA drive to this host card. I'm not sure how to set up the raid for this system. Do I set it up as striped? Mirrored?
Do I use OS Extended or journaled? Any other suggestions? Thanks.
PowerMac G5 Quad Caldigit S2VR 500GB SATA, G-SATA 320 GB drive and Fasta 4-E Host card.
Thanks so much!
David Issko
Re: setting up a raid Media 100 Hde
on Nov 5, 2006 at 9:09:21 pm
Sorry I can't be of any direct help to you but are you happy with the Caldigit HDDs?
It seems that 500Gb may be too small, I don't know.
I am looking to get HD Suite once M100 is UB and I will go for a Mac Pro. I have 8.2.2 on my dual 2GHz G5 that works a treat. The Caldigit Pro SATA setup looks so nice (from an uncompressed operational viewpoint) and seems to be a great solution at a reasonable price.
If you or anyone else has some feedback on Caldigit with M100 and high end HD like HDCAM - or anything HD, I would be most appreciative.
Thanks.
And by the way, my best guess Greg is Extended. I hope you find your solution quickly.
Floh
by
on Nov 6, 2006 at 7:36:55 am
For a RAID system you should use identical drives. If you want to work in uncompressed HD you would need at least 4 drives (probably more) striped as RAID 0 without journaling. Jpurnaling gives some additional data protection but slows down write access to the drives.
Greg
by
on Nov 6, 2006 at 3:16:50 pm
Thanks Floh-
I'm working with Beta SP and Mini DV only. Do I still stripe them as raid 0 no journaling? Thanks.
Also, I'm trying to figure out how to hook up the HDe junction box with my decks and monitor. The box came with a multipin cable that has numerous BNC Yrb and Yrc cables and some audio cables attached plus a Rs422 cable. Do all of these cables attach to my beta Deck (minus the AES audio cables I suppose)?
Are these the inputs and outputs I need for my beta sp deck? Then what are all of the connections in front of the junction box for? Lastly how would I incorporate an audio mixer and NTSC monitor into this set-up? Thanks.
Greg
Floh
by
on Nov 6, 2006 at 3:20:11 pm
[Greg] "Also, I'm trying to figure out how to hook up the HDe junction box with my decks and monitor. The box came with a multipin cable that has numerous BNC Yrb and Yrc cables and some audio cables attached plus a Rs422 cable. Do all of these cables attach to my beta Deck (minus the AES audio cables I suppose)?"
You either use the Breakout Box with the cable that has the multipin connecitons on both sides, or you don
Greg
by
on Nov 6, 2006 at 4:19:42 pm
My monitor has standard BNC inputs. I'm not sure I understand, Why would I not use the multipin? Is it possible to use a combination? Does the multipin connect directly to the deck? Can I use the front audio inputs and outputs to connect to my Mackie Audio mixer?
Floh
by
on Nov 6, 2006 at 4:24:52 pm
[Greg] "My monitor has standard BNC inputs"
Yes, but what signal? SDI? Component? Composite?
[Greg] "Why would I not use the multipin? Is it possible to use a combination?"
Look, you have one multipin connection on your HDe/Aja board. Either you use this multipin connector to connect the breakout box to the board with the supplied multipin/multipin cable, or you use the multipin to BNC/RS422/XLR connector cable and you forget the breakout box. You cannot use both at the same time.
