StreamClip Settings
COW Forums : Media 100
topher944
StreamClip Settings
on Nov 4, 2006 at 6:40:12 am
What are the best settings (highest quality) to use when exporting to quictime from Streamclip for use in M100 V8.2.2. Kind Regards, Chris K
Floh
Re: StreamClip Settings
by
on Nov 4, 2006 at 7:45:56 am
From MPEG Streanclip, export as Media 100 i 720 codec file (either PAL or NTSC), with a high data rate setting. This way you have to recompress only once, and for PAL you will stay in the DVD resolution (720*576), while for NTSC you only have to do a small conversion (480->486 lines). You probably will not notice any differente wether you will use e.g. 70% or 90% quality, since the source material (DVD) is somewhat limited.
