100i update to 8.2.3a problems?
COW Forums : Media 100
Nickel
on Oct 16, 2006 at 4:13:45 pm
Hi. I updated to 8.2.3a (see thread below "exporting to iPod difficulty" and I noticed that the application info says 8.2.3a, however, when I open the ap and go to "About Media 100" then it says 8.2.3 - no "a." Is this normal? Also, now when I attempt to export an iPod movie I get a crash instead of the error message. Thanks for any help.
Nick Lammers
Media Mill, Inc.
St. Louis, MO
Media 100i XS 8.2.2
Dual 1Ghz G4
Floh
Re: 100i update to 8.2.3a problems?
by
on Oct 16, 2006 at 4:39:50 pm
[Nickel] "Hi. I updated to 8.2.3a (see thread below "exporting to iPod difficulty" and I noticed that the application info says 8.2.3a, however, when I open the ap and go to "About Media 100" then it says 8.2.3 - no "a." Is this normal? "
Yes, unfortunately there is no way to tell which version you have from looking on the About Media 100 window. If you downloaded and installed V8.2.3a you should be good.
[Nickel] "Also, now when I attempt to export an iPod movie I get a crash instead of the error message. Thanks for any help."
Hmmm, which QuickTime/OS version do you use? The iPod export should work. Do you have installed any 3rd party QuickTime plugins? (In HardDrive->Library->QuickTime)
Nickel
on Oct 16, 2006 at 6:29:37 pm
Hi Floh. I have these in the QT file:
Flip4Mac WMV Export.component
Flip4Mac WMV Import.component
InstantMediaOSX.lib
Media 100 Transcoder.Component
Media 100 VOUT.Component
Media100 HD.component
Media100.component
I am running QT 7.1.3 and OS 10.4.8
Thanks again.
Nick Lammers
Media Mill, Inc.
St. Louis, MO
Media 100i XS 8.2.2
Dual 1Ghz G4
Nickel
Still there, Floh?
on Oct 18, 2006 at 5:26:11 pm
Floh, you may be busy or maybe just didn't see that I'd replied to your questions. Sorry to be a pest.
Nick Lammers
Media Mill, Inc.
St. Louis, MO
Media 100i XS 8.2.2
Dual 1Ghz G4
Floh
Re: Still there, Floh?
by
on Oct 18, 2006 at 6:27:10 pm
I
Nickel
on Oct 18, 2006 at 6:33:13 pm
Thanks - you have all the answers. I will go the "by ref" route. Everything else seems to work OK so I hate to change things around.
Nick Lammers
Media Mill, Inc.
St. Louis, MO
Media 100i XS 8.2.2
Dual 1Ghz G4
