video shears and tears
COW Forums : Media 100
egeefay
on Sep 25, 2006 at 10:34:07 pm
I've been having a problem with exports from After Effects to Media 100
Anytime there is quick movement in the rendered video...someone running by or a quick head turn the video looks like it is tearing or shearing...rather than a nice smooth movement.
Anyone had this problem?
Jim Calahan
Re: video shears and tears
on Sep 26, 2006 at 3:05:43 am
Is the video widescreen? It could be a size issue.
Jim Calahan
KVIE, Sacramento
Ben Heusner
on Sep 26, 2006 at 5:46:45 am
As Jim said, it's likely a size issue but also make sure you've rendered back to the correct Media 100 codec (NTSC/PAL, square/720).
You should check too that you've rendered with the correct field order.
HTH
Ben
Curious Turtle Professional Video
Training | Editing |Support
http://www.curiousturtle.com
Floh
by
on Sep 26, 2006 at 6:07:35 am
[egeefay] "I've been having a problem with exports from After Effects to Media 100
Anyone had this problem?"
Are you seeing this tearing on an interlaced monitor/CRT? Or on a TFT/Plasma? Are you seeing it in AE or Media 100? Are your clips field order interpreted correctly in AE (usually done automatically)? What is your comp size in AE (PAL 720*576 or NTSC 720*486, or something else)? Which codec are you rendering into?
