How can I easily convert 44100 Hz Audio to 48000 Hz?
COW Forums : Media 100
Jerome Robbins
on Sep 19, 2006 at 7:08:35 pm
Media 100i XR 8.2.3 G-4 Dual 144
I have always been using 44100 Hz as my input setting. I understand it is preferrable to use 48000 Hz for use in DVD StudioPro so I am now using the 48000 Hz input for audio.
The problem is I have a lot of music files that I access and use on my projects that are in 44100 Hz format. I just tried to open a music folder and drag a selection to my new program that is 48000 Hz and I got the message that I can't mix types in the same program.
My question is: is there an easy way to convert my 44100 music to 48000? I want to avoid re-importing everything I already have in files that is 44100 Hz.
Do I open my folders, choose a file, export it, and then re-import it with my hardware import settings set to 48000 Hz for the conversion?
Thanks for any help,
jerome
Greg
Re: How can I easily convert 44100 Hz Audio to 48000 Hz?
by
on Sep 19, 2006 at 7:20:16 pm
Why not burn your music files to CD then import the tracks from CD into your new program?
Dave LaRonde
on Sep 19, 2006 at 8:23:22 pm
Get Quicktime Pro. Best 30 bucks you'll ever spend.
Dave LaRonde
Sr. Promotion Producer
KCRG-TV
Kieran Matthew
on Sep 19, 2006 at 9:56:13 pm
Hi Jerome,
Set your hardware prefs to 48K. Use the import tool to re-import the audio file you want from the media drive. In the import dialogue, select "convert to 48000 Hz"
K
