Firestore for Mdeia 100 i V8
COW Forums : Media 100
filmphilosopher
on May 29, 2006 at 3:59:46 pm
Hello,
Has anyone heard of a firestore that will work with Media 100 i/V8 without the need for rendering new clips?
Daniel E
Re: Firestore for Mdeia 100 i V8
on May 30, 2006 at 8:27:09 pm
If the clips are recorded from the camera in a format you are using in your project or timeline they should be imported without out rendering. If they are different then your project settings then they will need to be rendered. The Firestore has settings for different systems so it is not just the device which determines the recording it is also the settings at the time of the recording
Daniel Epstein
Gold Teleproductions, Inc
New York, NY
http://www.goldtele.com
