m100 to AE on PC
COW Forums : Media 100
dankelly
m100 to AE on PC
on May 13, 2006 at 4:15:04 am
I need to read some m100 files, only digitized and handed to me (separated audio and video files) instead of a self contained exported file, to use on my pc (running AE7 and WinXP).
I downloaded the iFinish transcoder from m100.com, put into system32 folder and restarted my pc, as i
dankelly
Re: m100 to AE on PC
on May 13, 2006 at 4:19:28 am
forgot to mention that the files were digitized on m100 under osX, so i figured its m100 8, but not sure what version ('8.X'...)
thnx again
Dan
Floh
by
on May 13, 2006 at 9:57:55 am
The iFinish transcoder does not work with QuickTime 7 on a PC. If you are using QT7 you either have to downgrade to QuickTime 6.5 to use the Transcoder or to use another codec.
MichaelR
on May 15, 2006 at 3:00:44 pm
What if you edited the program using quicktime 7 on the mac...will the transcoder still work on that on the PC using quicktime 6.5, or must you edit on the Mac in quicktime 6.x also?
"The iFinish transcoder does not work with QuickTime 7 on a PC. If you are using QT7 you either have to downgrade to QuickTime 6.5 to use the Transcoder or to use another codec"
dankelly
on May 21, 2006 at 7:23:56 pm
I did downgrade to QT6.5, the video files worket just fine! But the audio files it doesnt recognize! (remember they
