Digital Juice editor's toolkit?
COW Forums : Media 100
Greg
by
on May 8, 2006 at 10:23:42 pm
Has anyone had experience using this with m100? I'm trying to use both their lower thirds and overlays, ut I can't figure out how to get these to work in M100.
I'd like to put these animated images on the graphics track. Any suggestios on how to prepare them and use them? I'd like to be able to resize them or move them on the graphics track. Thanks.
Lukkee
Re: Digital Juice editor's toolkit?
on May 9, 2006 at 2:26:39 am
You will need to render the files as quicktime out of the Juicer using the animation codec @ millions of colours +(alpha channel). Then import into Media 100 and drop on graphics track. You can then position and/or scale using the Media 100 editor.
Hope this helps.
lc
Greg
by
on May 9, 2006 at 11:43:53 pm
Thanks for your help. I can only see this after I import it into a bin and make it a composition cip. However I can't change the position of it, nor can I re-size it. Any thoughts? Also, Digital juice says to use the media 100 codec, but that option does not appear in juicer. Any more help would be appreciated
