Next Clip In Bin Double Skips - Bug?
COW Forums : Media 100
Michael C.
on May 3, 2006 at 12:48:56 am
Does anyone else have this issue?
When I use the next or previous clip buttons in the edit suite (to jump to the next clip in the bin), about 90% of the time it will jump ahead 2 clips (skiping the next clip). This makes it so you are forced to go back to click on each clip you're scanning individually...
...and on a dual monitor setup, this can be annoying. Anyone else with this problem?
Running 10.1.4 M100HD.
Thomas Hughes
Re: Next Clip In Bin Double Skips - Bug?
on May 4, 2006 at 9:43:47 pm
I have the same problem, I don't know the fix.
Michael C.
on May 5, 2006 at 12:05:21 am
I don't think there is a fix... It is just a really annoying bug. :(
SoftHarbor
on May 5, 2006 at 9:18:40 pm
The problem is that the button repeats while you hold it down. That might be useful in a giant bin if you want to cruise past a bunch. It seems to repeat a little too quickly. But you should be able to click quickly and beat the repeat.
Michael C.
on May 6, 2006 at 1:22:16 am
Nice! You nailed it. That's right.. thanks. I think they need to give that about a .5 delay eh?
