digitizing setting to maximize video quality
COW Forums : Media 100
macmauro
on Apr 30, 2006 at 2:05:31 pm
Hi
i shooted video in dvcam format; pal 720:576; 16:9 anamorphic
using 2 pd 150 sony cameras (3ccd)
at which quality i can digitize the video manteining the original video quality?
i can arrive at 360kb per frame, but isn't this more than the shooting quality?
PS which sotware i can use to convert 4:3 to 16:9
thanks a lot
Maurizio
Floh
Re: digitizing setting to maximize video quality
by
on Apr 30, 2006 at 3:05:27 pm
For online quality from DVCam I would suggest something around 240k PAL. DVCam data rates are lower than that, but since the signal gets converted to uncompressed and then recompressed to the Media 100 i codec it makes sense to keep the data rate higher. On recompression artifacts could appear when using lower data rates.
[macmauro] "PS which sotware i can use to convert 4:3 to 16:9"
E.g. AfterEffects. Or Media 100 sw, which is quite good at mixing 4:3 and 16:9 material.
macmauro
thanks 4 digitizing setting to maximize video quality
on Apr 30, 2006 at 5:31:13 pm
thank you Floh
excellent as always
M.
