after batch digitizing the player works slow
COW Forums : Media 100
macmauro
on Apr 27, 2006 at 7:32:57 pm
hi, i used my digital player for batch digitizing in m100
via firewire (i know i have to use it via RS422 connector )
the problem now is that when i control the deck from m100
to forward or backward the tape while the play button is on
the deck doesn't run fast as it did before
but move the images slowly, frame by frame,
also using the keyboard
why? What can i do to reverse this function?
thanks
Maurizio
Kieran Matthew
Re: after batch digitizing the player works slow
on Apr 27, 2006 at 9:44:21 pm
I'm guessing here, but it sounds like you've got it in "jog" mode rather than "shuttle". You can toggle between them with that oval button with the two arrows to the left of the transport buttons on the Digitise pane.
Hope that helps
