Exporting AE renders to import as 16x9
COW Forums : Media 100
Bobby Mosaedi
on Apr 27, 2006 at 1:59:35 am
What render settings do i need or import settings in m100i to get media100 to recognize my imports as 16x9? this is really frustrating because it will only interpret them as 4x3.
After Effects:
Composition Settings:
NTSC D1 720x486
Pixel aspect ratio: 1.2 NTSC/DV widescreen
Render Settings:
Field dominance: Lower
Output module:
Media 100 NTSC 720, medium quality
Media 100i hardware settings :
720x486, 16x9 , 48,000 audio
what else do i need to do?
Floh
Re: Exporting AE renders to import as 16x9
by
on Apr 27, 2006 at 6:25:18 am
[Bobby Mosaedi] "what else do i need to do?"
In the "Import" dialog box, set Aspect ratio to 16:9. Or select your clip in your Bin and use the Media->Change Media Attributes
Bobby Mosaedi
on Apr 28, 2006 at 10:24:27 pm
there is no way to change your aspect in the bin. I tried changin media attributes and the only thing it lets me change is my input setup, reel name and clip name. There has to be a way. Does nobody else create AE renders for 16x9 timelines?
Kieran Matthew
on Apr 29, 2006 at 4:22:08 pm
Hi Bobby,
When you import the clip into media100, rather than drag it into the bin, use the import option from the menu. From here you can set the aspect ratio of the incoming clip in the drop down at the bottom. Although it defaults to "honor file's aspect", setting it to "Use 16:9 aspect ratio" will have the desired effect.
