after effects export
COW Forums : Media 100
EclecticBubba
on Apr 20, 2006 at 8:40:47 pm
tried to "export to After Effects" program and keep getting an xml file.
used to get an M1a file?
Using G4, 8.2.3 (downloaded 8.2.3a, but don't see the "a" reflected in version on the About screen.)
AE 6.5
have the M100 plug in for AE
any thoughts?
bubba
Floh
Re: after effects export
by
on Apr 20, 2006 at 8:43:29 pm
Did you put the *new* Plugin for AE (the one that gets installed with V8.2.3a) into the correct AE folder? It is right that V8.2.3 now exports XML files to AE, and you need the new plugin to read them.
EclecticBubba
on Apr 20, 2006 at 8:47:55 pm
Floh,
it installed to
After Effects - PlugIns - Standard - Format - fpf - M100ProjectImporter
thanks,
bub
Floh
by
on Apr 20, 2006 at 10:11:20 pm
Inside your Applications->Media 100 i folder should be a folder labeled Adobe AfterEffeccts Plugin. In that folder is the Media 100 XML Project Importer. Copy this into your Applications>Adobe AfterEffects->Plugins->Standard->Format folder and you should be up and running.
EclecticBubba
on Apr 21, 2006 at 3:37:04 pm
thanks Floh, "you done it again!" saved the day.
I'm gettng a slight error, when I import the file to AE, (6.5), it takes most of the file, but then reads: After Effects: AEGP Plugin Media 100 XML Program Importer: Assertion Failed: lastEffectInfo = = OL at (module info not available) [0x00000000]
and the comp comes up a couple shots short of a full timeline...
any thoughts?
again, thanks
bubba
EclecticBubba
on Apr 21, 2006 at 3:46:41 pm
Nevermind Floh, it doesn't like Media100 black... I took out the black slug at the end and got a good import.
Thank you again.
bubba
