720 on my vincent
COW Forums : Media 100
Bobby Mosaedi
720 on my vincent
on Apr 15, 2006 at 3:02:38 pm
I recently upgraded an old version 5.5 xs to 8.2 for osx to use as a digitizing station. but the 720x486 box is grayed out and i cant select it. what gives? i found an article on media100''s site talking about enabling an analog 601 checkbox in my hardware preferences, but i dont see it. I didnt spendthe upgrade money just so i could have logged bins! is there a way to enable 720 for 601 cards?
http://support.media100.com/KBSearch/kbDocument.aspx?id=358
Floh
Re: 720 on my vincent
by
on Apr 15, 2006 at 3:37:01 pm
The original Vincent board does not support 601 formats (720*576 and 720*486) at all. Are you sure you have a Vincent 601?
sformby
on Apr 17, 2006 at 5:13:43 pm
There is a 720 enabler utility "Media100720EnablerV102.sea.hqx" that will "flash" a 601 board. Here's the read me for it. I used it on my 601, and it worked like a charm in 7.5.
ftp.media100.com/pub/software/Media100i/Media100720EnablerV102.sea.hqx
Media 100
sformby
on Apr 17, 2006 at 5:34:36 pm
Just re-read that ReadMe. Looks like it is a software fix, not a flasher.
Bobby Mosaedi
on Apr 18, 2006 at 3:23:49 am
hey is this only for os 9? do i need to boot the machine in os 9 and then flash/install the update and then boot back into 10 to use in version 8? i used to have to do this to flash DVD-R drives.
RobM
by
on Apr 18, 2006 at 2:39:45 pm
[Bobby Mosaedi] "hey is this only for os 9?"
Yes, the 720 enabler is only necessary (and only works) for/in M100 in OS 9. And you need a Vincent 601 board.
[Bobby Mosaedi] "do i need to boot the machine in os 9 and then flash/install the update and then boot back into 10 to use in version 8?"
No. Did you did read the kb article you cited? The functionality of the 720 enabler was built into the v 8.x software for OS X. The Analog 601 option will only appear in the hw prefs if you have a Vincent 601 board installed. Ergo, I'm guessing you have a Vincent TM board and not a Vincent 601, as Floh also implied.
If I recall correctly, the about box in M100 lists what type of board you have, along with its serial. Or maybe its the diags. A P6000 lists as P6000. Vincent 601 = Vincent 601. Vincent TM = Just plain ol' "Vincent."
sformby
on Apr 18, 2006 at 4:45:34 am
I'd give it a try in OS 9 and see if it works. Report back!
The King
on Apr 18, 2006 at 7:26:59 pm
if its a vincent 601 card and you're running 8.2 there should be a little check box in the hardware preferences
enable 601 or 720 or something like that.
Dah King
