Old Media 100 Programs - Wrong Audio Rate and Resolution - Convert?
COW Forums : Media 100
Michael C.
on Apr 10, 2006 at 10:17:27 pm
I hope this isn't a double post... (I don't know where the original question went).
Anyway... I need to take an old M100i program (640x480 and 44116Hz) which is completey offline and manually replace each edit with new media (720x486 and 44100) that is already digitized into the M100HD system.
I thought I could do an edl out, then back in, but that remaps the audio tracks.
I can export an XML file, but that doesn't re-import into the M100HD w/o an error.
I don't see any way to simply get this program to re-conform to a new resolution and audio frequency.
Any ideas?
(I don't want to go back to the tapes and re-dig using command/option/control because all the media I need is already on the system). So how would I do this?
Floh
Re: Old Media 100 Programs - Wrong Audio Rate and Resolution - Convert?
by
on Apr 11, 2006 at 6:02:09 am
[Michael C.] "Anyway... I need to take an old M100i program (640x480 and 44116Hz) which is completey offline and manually replace each edit with new media (720x486 and 44100) that is already digitized into the M100HD system."
Actually I would recommend to always work in 48kHz, since all digital decks (DigiBeta, DVCPro,...) record at 48kHz.
[Michael C.] "(I don't want to go back to the tapes and re-dig using command/option/control because all the media I need is already on the system). So how would I do this?"
I
Michael C.
on Apr 11, 2006 at 6:11:34 pm
Good idea... I'll try that!
Michael C.
on Apr 11, 2006 at 6:27:50 pm
That worked flawlessly... Thnanks Floh!
