Exporting from Edit Suite
COW Forums : Media 100
Vis101
on Mar 29, 2006 at 5:37:47 pm
Hi, we are running Media 100i/xs with 8.2.2 and OS 10.3.9 on a G4 Dual 1 Ghz Processor, 1.5 Gb DDR SDRAM and 2 - internal Sata 400Gb HDs. We are attempting to export from edit suite in QT H.264 to then burn to DVD. Is this process extremely slow by default with Media 100 or are we doing someting wrong in the set-up? We have a 55mins show in 720x480 with audio and the G4 has been crunching for 19hours now and it is still going.
Any ideas, thanks,
Thierry.
Thomas
Re: Exporting from Edit Suite
on Mar 29, 2006 at 11:17:23 pm
Export from edit suite by ref (extremely fast), then encode with bitvice or toast (or DVD studiopro but with this one you have to check before the black levels of your clip), then author in DVDSP and burn. Why H. 264?
Tommy
Vis101
on Mar 30, 2006 at 3:25:08 pm
Thanks to all for your input.
Thierry.
softharbor
on Mar 30, 2006 at 2:54:32 pm
h.264 uses a multi-pass encoding algorithm, so it's going to be pretty slow, especially on your old G4.
