how to import a M100 XML file into AE6 as a composition?
COW Forums : Media 100
carlos azm
on Mar 11, 2006 at 9:56:19 am
I just recently upgraded to M100 version 8.2.3 and I have notice that now when I try to export a program to After effects v.6 I get a XML file. When I import the flie into AE6, all I get is a folder with all the clips but no longer a composition with the clips in the same order as I have them in the timeline in Media 100. How can I get them into a composition as before?
Thank you for any answer
Carlos
matt short
Re: how to import a M100 XML file into AE6 as a composition?
on Mar 12, 2006 at 4:15:00 pm
Are you importing as a composition or footage?
Floh
by
on Mar 12, 2006 at 4:16:28 pm
[carlos azm] "I just recently upgraded to M100 version 8.2.3 and I have notice that now when I try to export a program to After effects v.6 I get a XML file. When I import the flie into AE6, all I get is a folder with all the clips but no longer a composition with the clips in the same order as I have them in the timeline in Media 100. How can I get them into a composition as before?"
There *should* be a composition somewhere within the folder with all the footage clips. Are you sure that there is no Comp in the folder?
