Mini DV Deck hook-up Floh
COW Forums : Media 100
Greg
by
on Mar 4, 2006 at 9:35:01 pm
Floh, a short time ago you asked someone "Do you have a DV board for Media 100? Do you connect the DV deck to the FireWire port on the P6000 board (not the one on the G3/G4/G5)? What DV deck do you use?
I have the same issue. I have a Sony DSR-20 and I also have the DV option for media 100. My deck is connected to the DV board coming out of the G4. Should I be getting machine control? Also, this may sound like a stupid question, but does audio travel on the same firewire? Or do i need to connect audio outs to the m1oo junction box? Thanks. Honestly, I've never used this option. Thanks.
matt short
Re: Mini DV Deck hook-up Floh
on Mar 4, 2006 at 10:37:12 pm
[Greg] "Should I be getting machine control? Also, this may sound like a stupid question, but does audio travel on the same firewire?"
Everything goes through the firewire, (video, audio and machine control). Although, the machine control is much more responsive if you connect via the RS-422. Does the DSR-20 have RS-422? Be sure to set the proper inputs and machine control in the settings window.
