Pre built graphics into Media100i
COW Forums : Media 100
Topher944
on Mar 2, 2006 at 2:49:20 am
Hi Folks, I'm trying to import some prebuilt graphics into media 100i 8.2.2. I've looked at the files and they do have an alpha channel embedded. I can't see my video track through the alpha (black). I've tried "import" thru M100 and thru after effects with millions colors + selected. I've laid them on a FCP project and they work perfectly. I'm am tired so I could be having a brain hiccup. What's the process? They're mov files from a disk. Do they go in the graphics trax or video trax? Please help this mindless twit! Thanks in advance for your time. Chris
john
Re: Pre built graphics into Media100i
by
on Mar 2, 2006 at 10:40:59 am
try dropping onto the grafix track and make sure fade up and down sliders are set to zero
Greg Quitiquit
on Mar 3, 2006 at 9:38:57 pm
Also, make sure you do not have "Scale Out of Range RGB Values" checked on the import dialog box.
Greg Quitiquit
topher944
Re: Thanks, both were good suggestions!!
on Mar 4, 2006 at 10:08:48 pm
Thanks! both were good suggestions!
