RE: Media 100i LE 8.2.3 not working outside Media 100 app
COW Forums : Media 100
gerrym
on Feb 25, 2006 at 9:59:37 pm
Im running Quicksilver 933 G4 - system 10.3.9
Quicktime - 7.0.4
I uninstalled 8.2.1 and installed 8.2.3...
Media 100 application works fine...
but Quicktime Player, Cleaner, bring up a white video screen??
I uninstalled and it was fine??
any suggestions?
gerry
gerrym
Re: RE: Media 100i LE 8.2.3 not working outside Media 100 app
on Feb 25, 2006 at 10:00:48 pm
Sorry, Its the old Vincent 601 board...
Have I come to the end??
Kieran Matthew
on Feb 25, 2006 at 10:18:18 pm
I had a similar problem a while back and it was cured by downloading and installing the software codecs from Media100.com.
I don't know if it will cure your issue, but it is worth a try!
gerrym
on Feb 26, 2006 at 2:23:50 am
Well, I tried the software codec... but no success...
Its either the end of the line for the Vincent board... Though shes had a great run!
or maybe Tiger is the solution?
Anybody running a G4 with tiger, and the old Media 100 vincent 601 & software 8.2.3?
gerry
Floh
by
on Feb 26, 2006 at 11:08:39 am
If QuickTime based applications don
gerrym
on Feb 26, 2006 at 9:49:16 pm
Thanks for your response,
Turns out I had to take the Media hardware codec out of the LIBRARY/QUICKTIME for both the main system and the user library...
So it looks like me old Vincent board is still going to chug along with the SD format for a while longer...
I guess i will be missing the classic Media 100 warning
" Your hardeware is in use by another app... quit Media 100 blah...blah...blah..."
Viva la Media 100!!!
thanks again for your suggestions...
gerry :{)
