a green line in digitalized clip
COW Forums : Media 100
macmauro
on Feb 16, 2006 at 8:06:48 pm
hi
i discovered that when i digitize video from dv and mini dv tape
into media 100 i 8.2.2 -
Jade448
Re: a green line in digitalized clip
on Mar 10, 2006 at 9:50:03 pm
Yes this is a DVCAM issue. Its the timecode information that normally becomes visible with the underscan switched on the monitor. Also when you preview your settings before encoding this will show on a computer display. You need to crop the top few lines manually. Do this before encoding and you should be OK.
