Fastest Way To Import FCP .MOV files into MEDIA 100HD?
COW Forums : Media 100
Michael C.
on Feb 16, 2006 at 5:31:52 pm
I have a client coming in later today to do a quick edit. They've got about 30 pieces saved to DVD as FCP .mov files.
[It looks like the format is DV/DVCPRO 29.97 NTSC 720 x 480. 16-bit Integer (Big Endian), Stereo, 48.000 kHz - Data Rate: 30.38 mbits/sec]
I do have FCP, but don't want to edit on that. Is there a way to quickly import these into the M100HD? A 5 1/2 minute clip takes about 10 minutes to import
Floh
Re: Fastest Way To Import FCP .MOV files into MEDIA 100HD?
by
on Feb 16, 2006 at 5:33:55 pm
If the files are DV/DVCPro they should "fast import", meaning that they don
Michael C.
on Feb 16, 2006 at 5:48:07 pm
Thanks Floh... I'm importing off of the DVD-R... But I'll try bringing it to the drive first...
But won't it still change the file to a M100 codec file? (I'm using M100i 100kb codec for these)... What import settings would I use to make them "fast import"?
Thanks.
Floh
by
on Feb 16, 2006 at 5:54:41 pm
If the files are in a Media 100 "realtime" codec (Media 100 i, HD, 844/X, Animation, DV(25)) they should fast import and not change their codec. If you open the "Import" dialog you will see a "Import Media to the standard and Compressor" checkbox. If this is checked the files get transcoded into the selected codec. If it is not checked supported codecs should "fast import". We do a lot of exchange with FCP DV codecs in realtime playback. Really very helpful...
Michael C.
on Feb 16, 2006 at 5:56:22 pm
I'm not sure why the FCP files aren't fast importing then. Weird.
Floh
by
on Feb 21, 2006 at 7:04:39 pm
[Michael C.] "I'm not sure why the FCP files aren't fast importing then. Weird."
Probably it is much too late now, but are you running Media 100 HD 10.1.2 or 10.1.3, or are you running an earlier version? I think I can remember that FastImport of FCP DV media was fixed in 10.1.2 and did not work in earlier versions.
