Bad Monitoring of Component Signal
COW Forums : Media 100
J Jordan
on Feb 4, 2006 at 1:08:35 am
We Are loading 16:9 component signal into Media 100 8.22. When we monitor the digitizing signal it is scrambled. But the digitized footage plays back fine. It's just a slightly annoying problem while digitizing. We are loading component out 480p from a HDV deck and have had similar situation when loading component off of DVD.
J Jordan
Floh
Re: Bad Monitoring of Component Signal
by
on Feb 4, 2006 at 8:35:17 am
When digitizing component signals you also should connect a Composite out signal to the Composite in of Media 100 as a reference. This should fix the problem.
J Jordan
on Feb 4, 2006 at 4:23:19 pm
It's not scrambled anymore but my color is all over the place, just in digitizing. Plays back fine.
Thanks Floh!
