M100Project Exporter & AE7
COW Forums : Media 100
JayInSacramento
on Jan 26, 2006 at 8:23:47 pm
As far as I can tell, the Media 100 Project Exporter doesn't work with the new After Effects 7. Has anyone found differently or heard that they will be updating it?
Floh
Re: M100Project Exporter & AE7
by
on Jan 27, 2006 at 10:49:01 am
Are you speaking about Media 100 i or HD/sw? The HD importer seems to work from my initial tests, but I haven
JayInSacramento
on Jan 27, 2006 at 7:40:56 pm
I'm using M100i. I did try putting the M100ProjectImporter in the Format Folder in Standard PlugIns in AE7. In AE6.5, there was a folder within Formats called fpf and that's where the M100ProjectImporter PlugIn went. So I also tried copying the fpf folder over too. Either way, when I go to import a M100 project, they are all grayed out so the PlugIn must not be working.
j
Floh
by
on Jan 27, 2006 at 7:45:27 pm
An (more or less) easy workaround would be to import the Media 100 files into AE6.5, save the project and open it in AE7. Should work, but obviously is an extra step.
JayInSacramento
on Jan 27, 2006 at 7:48:50 pm
Good idea. I'll do that until M100 comes out with an updated Project Importer PlugIn.
Thanks.
Floh
by
on Feb 22, 2006 at 3:48:30 pm
Seems like the new V8.2.3 should fix the AE7 import problem.
JayInSacramento
on Feb 23, 2006 at 5:08:10 am
Thanks, Floh, for the info. I'm glad to see M100 (Boris) is updating.
j
