ATTO UL4D with Media 100i ver. 8.2.2
COW Forums : Media 100
Warren
on Jan 25, 2006 at 4:02:39 pm
Does anyone know if the ATTO UL4D will work properly in a Dual 1.42 G4 running Panther 10.3.9 and Media 100i ver. 8.2.2? Recently recieved the UL4D card and have been using UL3D card with Media 100.
TIA,
Warren
matt short
Re: ATTO UL4D with Media 100i ver. 8.2.2
on Jan 25, 2006 at 7:17:43 pm
From ATTO's website...
"Backward compatible with PCI-based systems, preserving investment in legacy systems
133 MHz PCI-X provides up to 1 GB/second data transfers, allowing full Ultra320 performance
Fully backward compatible with 66 MHz and 33 MHz PCI specifications.
Fully compatible with 64-bit and 32-bit PCI busses"
If you have a UL3D why do you need a UL4D? Using Media100i, the UL3D is more than sufficient.
Warren
on Jan 26, 2006 at 6:29:41 pm
I happened on one and know someone that can use a UL3D card. So if it will work in my current system, everyone is happy.
Warren
