Importing Media100 SW Beta Project Timeline into After Effects.
COW Forums : Media 100
admarkjamaica
on Dec 11, 2005 at 4:58:53 am
Dear All,
I am trying to import my Media100 SW Timeline into After Effects as I have done countless times using 8i. What is interesting is that it creates an XML file. What is this and why is it there. It hangs my machine every time I try to import it into AE.
Should I give up on this and re-edit it on Final Cut? I need to finish this project on Monday. All advice will be much appreciated.
Cheers,
JJ
jj.foote@mac.com
Floh
Re: Importing Media100 SW Beta Project Timeline into After Effects.
by
on Dec 11, 2005 at 10:16:53 am
[admarkjamaica] "I am trying to import my Media100 SW Timeline into After Effects as I have done countless times using 8i. What is interesting is that it creates an XML file. What is this and why is it there."
Media 100 uses XML as a exchange format with AfterEffects. It
admarkjamaica
on Dec 11, 2005 at 5:52:28 pm
Do I still export in the same way?
jj.foote@mac.com
Floh
by
on Dec 11, 2005 at 5:57:11 pm
[admarkjamaica] "Do I still export in the same way?"
You export using the File->Export->Export to AfterEffects command. You need to place the "Media 100 Project XML Importer" into the AfterEffects->PlugIns->Standard->Format->fpf folder.
admarkjamaica
on Dec 11, 2005 at 6:31:33 pm
Thanks... I will try it first thing tomorrow morning
jj.foote@mac.com
