i can't import FinalCut files in M100, problems with upper/lower field
COW Forums : Media 100
macmauro
on Nov 28, 2005 at 1:16:03 am
I tryed to import in M100 8.2.2 os 10.3.9
files PAL at DV quality 720x576 created in and exported from Final Cut Pro 4 as quick time
when m100 is asked to import these files a message appears saying
i have to use upper field option in quick time when i create the file
anyway it imports the file but the result is a bad motion and strange colors clip
but also using the upper field option in Final Cut the message still appears
and the result is the same
the media100 runs under Quicktime 6.4
Final cut under quick time 7.
Could this be the problem?
How to avoid it?
in case could i upgrade to QT 7 the media100 computer?
thanks
