Can't export from edit suite? What do I need to do?
COW Forums : Media 100
Jerome Robbins
on Nov 26, 2005 at 1:49:00 am
From an earlier post, I had some clips that had been digitized at a 60 instead of 300 quality. I redigitized all the original clips into a bin at 300. I replaced all the lower quality clips with the new ones. This was an all day fix.
Now, I went to Export from the edit suite ,as I want to export the program as a QT movie for authoring in DVD Studio Pro. The Export from Edit Suite is grayed out and not avaliable as an option.
What could be causing this and what can I do to fix it? This project is stopping me at every turn.
Thanks for continues help,
Jerome
Floh
Re: Can't export from edit suite? What do I need to do?
by
on Nov 26, 2005 at 6:50:11 am
Open the "Monitor" or the Source & Record window. It can happen that Export from Edit suite is greyed out if the Recod window is not opened.
