If Media 100 only had the "snap-to" function.
COW Forums : Media 100
Jim Wigler
on Oct 28, 2005 at 3:56:58 pm
Occasionally, in the flurry of editing, I inadvertently leave a BLANK FRAME on the timeline. None of the "close gaps" functions seem to work over multiple clips. Is this just me or am I missing something?
J m Wigler
Bernie Huth
Re: If Media 100 only had the "snap-to" function.
on Oct 29, 2005 at 4:55:15 pm
Under the Tools Menu there is:
Snap to other clips with a keyboard shortcut of Uppercase-Command-1.
For removing gaps there are three possibilities under the Program Menu:
Remove All Gaps - Command-K
Remove Gaps to End - Command-J
Remove Gaps in Range - Command-R
HTH
Bernie Huth
Digital Media Specialist
San Jose, CA
Jim Wigler
Thank you! I'll try to get it to work right.
on Oct 29, 2005 at 7:44:21 pm
Thank you, Bernie!
I'll try and get it to work correctly. But with multiple clips, all I get is the error alert.
