M100 problem with DV option
COW Forums : Media 100
carlos azm
on Oct 25, 2005 at 11:40:11 am
I work with a G5 OSX 10.3 and a Media 100 v.8.2.2. The problem is that I get a solarize picture triying to master to tape or while digitizing through the DV option. It does not happen using the component or S-video input/output. I have changed firewire cables, different DV decks. I run the M100 application test and everything was OK.
Has anyone an idea of what might cause this problem?
jacobo vizcarra
Re: M100 problem with DV option
on Oct 26, 2005 at 8:16:23 pm
Try resitting the card. I moved around my system and was having problems that did the job for me.
jacobo vizcarra
macedo advertising inc.
carlos azm
on Oct 27, 2005 at 7:37:40 am
Thanks, Jacobo
I did that and now it works fine.
