RS422 cable
COW Forums : Media 100
joe
RS422 cable
by
on Aug 12, 2005 at 2:44:20 pm
I just picked up a used M100 V8 LX and want to get a cable to connect my SonyUVW1800 to a G4 Dual 1ghz OSX.28 for machine control.
In Hardware Preferences under machine control I have two options:
Media 100DV and TimecoderXM100.
I assume I just need a 9pin connector(back of uvw1800) to a phone plug type connector (modem port back of G4).
Is there an outlet that specializes in these cables?
Thanks for any info.
Cheers,
Joe
Floh
Re: RS422 cable
by
on Aug 12, 2005 at 2:57:45 pm
You can buy them from e.g. Pipeline. You need the Mac version.
joe
Danke
by
on Aug 12, 2005 at 3:07:09 pm
Thank you Floh.
Cheers,
Joe
joe
Keyspan or Stealth?
by
on Aug 12, 2005 at 3:38:12 pm
It appears I will need to get either a Keyspan Serial adaptor or the Stealth Serial Port to connect the cable to the Mac.
I did a search on both; nothing really hinted at which might be better although Keyspan seemed to come up more often.
Is one more reliable than the other?
Again Dual 1Ghz G4 OSX.28 Media100 V8.0
Thanks again for any info.
Cheers,
Joe
Floh
Re: Keyspan or Stealth?
by
on Aug 12, 2005 at 3:47:00 pm
I definitely would recommend the Keyspan. No hassle with modifying your CPU, and if you upgrade to a new Computer you don
joe
Thanks again...
by
on Aug 12, 2005 at 3:53:04 pm
Danke.
Cheers,
Joe
