getting bins out of Media 100i into a Media Composer
COW Forums : Media 100
Michael T.
on Aug 9, 2005 at 8:20:10 pm
Anyone out there have any experience in taking a project from a media 100i system into an avid media composer 11.2.6 running on Mac os9.2. Is there a way to export bins that have bin created in media 100i so that I can import and redig the material on the media composer? Thanks for your help.
bouke
Re: getting bins out of Media 100i into a Media Composer
on Aug 14, 2005 at 11:09:11 am
Set your bins in list view, select all and copy, paste in a text editor.
Now from here it's easy to convert them to a .ale file.
I assume you know the routine, but just in case, an ALE should look like this
Heading
FIELD_DELIM TABS
VIDEO_FORMAT PAL
AUDIO_FORMAT 48khz
FPS 25
Column
Name Start End Tape Tracks Scene Customname1 Customname2
Data
1 17:15:38:16 17:15:58:18 GVL17 VA1A2 Chantilly totaal bib met td en licht uit?
2 17:16:38:02 17:16:50:15 GVL17 VA1A2 Chantilly binneplaats pan
or, alternative,
Heading
FIELD_DELIM TABS
VIDEO_FORMAT PAL
AUDIO_FORMAT 48khz
TAPE myTape01
FPS 25
Column
Name Start End Mark IN Mark OUT Tracks Comment
Data
01:17:47:21 01:19:28:14 01:17:48:21 01:19:27:14 VA1A2 goffertpark en stadion en openluchttheater
hth
bouke
bouke
on Aug 14, 2005 at 11:10:56 am
Mind you, M100 DOES NOT store sequences in bins. They are stored seperate. If you want to redig a sequence you must go trough an EDL.
bouke
