question to speed up the work flow
COW Forums : Media 100
Kim
by
on Jun 30, 2005 at 1:48:37 pm
Hello all.
Let's say I want to copy a group of clips into a new bin.
Is there a way to "rubber band" select a group of consecutive clips in a bin without having to shift click each individual clip?
kim
While I'm at it... is there a way to have new audio tracks default to "show audio waveform"? It's not life or death but it sure would be nice to have the option without having to do it manually each time.
Kim
Re: question to speed up the work flow
by
on Jun 30, 2005 at 1:52:40 pm
PS: Sorry, I forgot to give some system specs regarding my post
OS is OXS X 10.3.9 Media 100i version is 8.2.2
Kim
Floh
by
on Jun 30, 2005 at 2:00:24 pm
[Kim] "Is there a way to "rubber band" select a group of consecutive clips in a bin without having to shift click each individual clip? "
Not in List mode. In Poster mode you can do it using "Alt" dragging.
[Kim] "While I'm at it... is there a way to have new audio tracks default to "show audio waveform"? It's not life or death but it sure would be nice to have the option without having to do it manually each time."
No. Only with an AppleScript. I use one to create new timelines with audio waveforms turned on.
Kim
by
on Jun 30, 2005 at 2:07:18 pm
OK Thanks. In fact I was in list mode. I find that when in any size poster mode it's hard to rubber band if you need to start on the far left size of the bin. There doesn't seem to be enough "room" around the clip to get the pointer there. No big deal, just part of those little things that would make things a little easier.
Thanks for your time.
kim
