Media 100 1 8.2 Activating the Uncommpressed settings
COW Forums : Media 100
Sal
by
on May 23, 2005 at 3:10:43 pm
Just wondering if anyne has upgraded to Media100i 8.2.1 without selecting the lossless option and then went back and was able to change the settings to allow the lossless option to be active. Right now i can see it in my media settings window but can not select it. I tried reinstalling the software but that did not work.
Thanks in advance for your time.
Sal
Floh
Re: Media 100 1 8.2 Activating the Uncommpressed settings
by
on May 23, 2005 at 3:14:20 pm
Do you have a lossless capable P6000 board? If not, you cannot use the lossless compression.
Sal
by
on May 23, 2005 at 4:37:48 pm
Yes I have a P6000.
When I did the intial install the application asked me if I wanted to activate the lossless setting; at the time i selected not too because of hard drive space.
However, I am trying to capture and composite some green screen segments and the compression is killing the effectiveness of the keying abilitiy.
Sal
Floh
by
on May 23, 2005 at 4:43:08 pm
[Sal] "Yes I have a P6000. "
Do you have a P6000 LOSSLESS capable? You should see that in the "About" window of the application.
Sal
by
on May 23, 2005 at 6:43:37 pm
There is no language on the about scene that indicates lossless;
P6000:612260 (559)
Driver version
0.12.156.4
8.10.20.0
Sal
by
on May 24, 2005 at 2:23:52 pm
Thank you for your time...I called Media100 and finally got to someone who told me that my card was purchased pior to the uncommpressed card release.
Thanks, Sal.
