Applying dynamics to multiple audio clips
COW Forums : Media 100
Andy Taplin
on May 19, 2005 at 4:46:29 pm
This seems oddly laborious: unsync the clip, then apply to each track of the clip one at a time.
Anyone know how to apply a dynamic setting to multipe audio clips in one go? - preferably a whole audio track at once.
Andy Taplin
Greg
Re: Applying dynamics to multiple audio clips
by
on May 19, 2005 at 7:42:13 pm
I believe you can take the clip you've applied your audio effect to and apply that effect toany other unlocked clips by shift clicking on all the clips you want to add dynamics to, double clicking on the clip that has your dynamic effect, theedit suite should go to edit clip tab. Choose tools> apply audio effects to selected clips.
I believe you can do the same by selected your clis in a bin.
Andy Taplin
on May 20, 2005 at 8:54:01 am
Thanks Greg, I'll give that a try.
I don't know why M100 have made this so difficult?
Cheers
Andy Taplin
SoftHarbor
on May 21, 2005 at 2:23:57 pm
[Andy Taplin] "I don't know why M100 have made this so difficult?"
If you mean "why is it so hard to apply an effect to multiple clips," well, if you can suggest a simpler procedure than the one Greg gave, please do.
But if you mean "why can't I apply dynamics to synched clips," it's because applying a dynamic effect to a stereo clip is not the same as applying the effect to two mono clips. Most people use pairs of synched audio clips for stereo, but Media 100 i (and HD and sw) internally treat each audio track independently, so it isn't possible to correctly apply the effect in stereo. The designers illustrated that by not allowing dynamics to be applied to synched clips.
