Importing Clips from AE
COW Forums : Media 100
Mark Honer
on May 6, 2005 at 11:29:16 pm
I've created some clips in After Effects and am having a very annoying problem getting the clips to import correctly back into Media 100. The clips I've created look great when viewed in Quicktime. But when I import into M100, I'm getting some tearing video in the spots where there is a little motion on the screen. Whenever there's some movement, the video looks a little jittery or it tears.
I've tried using both the M100 and Animation codec in creating the file in AE...but both look the same when I import back into M100 to assemble the clips into a program. I've been using m100 for eight years and never seen this before. Running OS X with v 8.2.2.
Any help would be appreciated.
Tim Scarpino
Re: Importing Clips from AE
on May 9, 2005 at 8:05:05 pm
This might be a long-shot, but have you activated the anti-aliasing function on your effect? I don't have AE open right now, but on the timeline, for each layer, there's a slash that if it looks jagged, means the anti-aliasing is off. Click on the slash until it appears smooth, then make your movie and import into Media 100. Maybe this will help, though it will slow AE down a bit.
Good Luck,
Tim
egeefay
on Sep 25, 2006 at 10:29:13 pm
I have been having the same problem.
It always happens on movies rendered in After Effects
Did you find a fix?
egeefay
on Sep 25, 2006 at 10:29:48 pm
Did you find a fix?
