How do you get the number keys to work?
COW Forums : Media 100
Jerome Robbins
on May 4, 2005 at 8:51:35 pm
I am using Media 100i 8.2.2 XR on OS 10.3.9 Since I switched up from 7.5.1 on OS 9 there arer to functions not working. I can't use the number key pad but have to use the numbers on the keyboard.
Also I used to be able to hit Home to go to the beginning of the timeline and (Apple End) to go to the end of the timeline. What happens now when I hit (Apple End), is I go to the top of the timeline.
I am sure this is an easy fix. Let me know please.
Jerome
Floh
Re: How do you get the number keys to work?
by
on May 4, 2005 at 10:19:21 pm
To toggle to numeric entry either press the "Num Lock" key (in the upper left corner of the numeric keypad) or use the NumLock menu in Media 100 i. It either shows a arrow (play button), then you have deck control on the numeric keypad, or it shows a little numeric keypad, then you have numeric keys and deck control with Shift (as it was under OS9)
End of program is "End" key, not command-end.
Mike Weber
on May 4, 2005 at 10:19:34 pm
Hi Jerome
Hit the "clear" key on your keypad. That will toggle the keypad functionality. You can also toggle using the triangle/keypad icon in the menu bar, just the right of Window.
Mike
Jerome Robbins
on May 5, 2005 at 2:40:55 am
Thanks for the quick response. Working fine now.
Nick L.
on May 5, 2005 at 2:52:56 am
Hi. I can't get the number key to activate. In the menu, next to "Window" I see the 2 choices but they are both "grayed out" so I can't change them (there is a check next to "NumLock is Off"). Also, the clear button doesn't change anything. What am I missing?
Nick Lammers
Media Mill, Inc.
St. Louis, MO
Media 100i XS 8.2.1
Dual 1Ghz G4
Floh
by
on May 5, 2005 at 9:37:48 am
Are you sure that you
Nick L.
on May 5, 2005 at 2:20:45 pm
Hi Floh. I just checked - running 8.2.1. Same problem, though, can't change the setting from the menu or the keyboard. I'm assuming the upgrade to 8.2.2 is available on Media 100's website - I'll try updating.
Nick Lammers
Media Mill, Inc.
St. Louis, MO
Media 100i XS 8.2.1
Dual 1Ghz G4
