FLV files into m100?
COW Forums : Media 100
Greg
by
on May 3, 2005 at 11:52:17 pm
Is it possible to take a clients flash video clips and import them into m100i 8.2.1 so I can use the clips in a program? How would do that? Thanks
Steve Kownacki
Re: FLV files into m100?
on May 5, 2005 at 11:31:14 am
2 options:
it's been a while, but I think I had my flash guy export sequential stills in the correct aspect and video frame rate and with enough safe area. I think flash by default is 12 fps which will make your video really fast. That was about 2 years ago, the new version of flash probably has setting already.
one thing i did the other day was to use Snapz ($60US) screen capture software. screen res set for 1280x854; captured a streaming video file with a bounding box at the default of the movie 320x240; capture rate of 30fps; internal sound. brought the file to m100 keeping the aspect; the file was a bit larger than 1/2 screen and (for streaming video) looked amazing! Partly i'm sure because of fewer colors of NTSC.
steve
