Is it possible to change logged clips specs?
COW Forums : Media 100
dankelly
on Apr 18, 2005 at 2:48:10 am
After logged many clips with only video to batch dig. found out it was suposed to dig. audio too. Is it possible to change my logged clips or will i have to re-log EVERYTHING w/ audio tracks enable??
working on OS 9.22, m100 7.5.
Thanx in advance!
Dan
Jim Calahan
Re: Is it possible to change logged clips specs?
on Apr 18, 2005 at 2:06:43 pm
Export to powerlog do a find and replace on your VA1A2 and import it back in.
Jim Calahan
KVIE, Sacramento
dankelly
on Apr 20, 2005 at 12:00:30 am
thanx for your response... but i just cant find where to export a Powerlog, only an EDL. (i only see Powerlog on the import menu box), but fine, the edl worked ok, there was only one more prob.: i can only export it from my time line, and importing it back creates a new time line..... is it possible to do the same from and back to a bin???
thanx in adv
Dan Kelly
Floh
by
on Apr 20, 2005 at 7:07:07 am
Hi Dan,
the ability to change clip parts and to export a PowerLog has been added in V8.x versions. If you want you can send me the Bin, I will make the changes and then export it as a PowerLog that you can reimport. Or you can download the SW only version of Media 100 and do it for yourself,
dankelly
on Apr 20, 2005 at 12:28:34 pm
Hi Floh,
Thanx a lot for the info and help, but we had to send already an offline copy to the client this morning, so i just ended up reloggging the whole thing...... but it good to know there is a way to solve it next time (well, hopefully there wont have next time! 8)
again
THANX ALOT!
Dan
