16:9 SD editing on Media100HD
COW Forums : Media 100
CameronT
on Apr 12, 2005 at 6:37:23 am
Anyone experienced in editing SD footages shot on 16:9 and edited on Media 100HD. Can the Media 100HD output 16:9 (SD)or do we need a ratio aspect converter as in the case of the Media 100i ?
Floh
Re: 16:9 SD editing on Media100HD
by
on Apr 12, 2005 at 6:47:51 am
[CameronT] "Can the Media 100HD output 16:9 (SD)"
As Media 100 i, HD can output 16:9. I think you are mixing up some things there. If you shoot in 16:9 you will end up with 16:9 anamorph material, and Media 100 i and HD will output 16:9 anamorph. Probably you want to know if you can output the 16:9 material as 4:3 letterboxed (with black bars at the top and bottom)?!? Media 100 HD can do that, but it requires a "conform" render pass. For a 5 minute program this will take ~5 minutes to process.
Michael Slowe
on Apr 12, 2005 at 9:08:57 am
Floh, I am now in a muddle following your reply to the query! I have just been editing some 16:9 originated material and I thought that by setting the project preference to 16:9 I was getting genuine native 16:9 back. It is true that my Sony monitor, switched to 16:9, is giving a letterbox picture but I thought that was because it is only a 4:3 screen. What is this anamorph that you refer to?
On another subject I am now editing HDV (converted to DV for the time being) on Media100i and hope that after NAB there will be a magic solution (from somewhere, maybe not Media 100) which will make it possible to edit HDV on Media100 HD - any further thoughts on this?
Michael Slowe
Floh
by
on Apr 12, 2005 at 10:15:38 am
16:9 Anamorph is what you are seeing. If you need to switch your Monitor to 16:9 to display the correct image you have an anamorph signal (the pixels are not square but stretched). Otherwise you have a 4:3 letterboxed image (16:9 with black bars, but always displayed at 4:3 ratio, and with the disadvantage of loosing the resolution you got with the anamorph 16:9 image).
[Michael Slowe] "On another subject I am now editing HDV (converted to DV for the time being) on Media100i and hope that after NAB there will be a magic solution (from somewhere, maybe not Media 100) which will make it possible to edit HDV on Media100 HD - any further thoughts on this?"
Media 100 is working on a FireWire support solution for Media 100 HD and sw. I don
Michael Slowe
on Apr 12, 2005 at 3:36:46 pm
Thanks Floh, that would be a good start but would Version 10 HD, even with firewire, be able to take in HDV, allow us to edit in the normal way, and master back an HDV programme? The format has pretty darn good picture quality we are told but not much good if we have to downgrade to DV to do anything with it. Are Media 100 likely to find a way to overcome the fact that HDV is MPEG compressed?
Michael Slowe
Floh
by
on Apr 12, 2005 at 5:10:18 pm
[Michael Slowe] "Are Media 100 likely to find a way to overcome the fact that HDV is MPEG compressed?"
I think so. I think the more tricky point than the MPEG compression is the fact that HDV uses LongGOP compression, which does not give you a full image on every frame. But I think that HDV is a very interesting format these days, and I believe they will find a way to support that.
CameronT
on Apr 14, 2005 at 2:46:47 am
Thank you all for your responses. I've got the reply from Media 100 that "SD 16:9 video out is anamorphic so you need to run it through a router or some other device to give you your letterboxed look" So it seems we can't get that letterboxed look directly output from the Media 100HD. Looks like I need to get an aspect ratio converter or something.
Floh
by
on Apr 14, 2005 at 6:56:50 am
[CameronT] "Looks like I need to get an aspect ratio converter or something"
As I said, you also can use the "Conform" command to convert your 16:9 anamorphic material to 4:3 letterboxed. It will need to process, but it is quick.
Michael C.
on Apr 14, 2005 at 4:06:38 pm
There is still no real-time way to output a 16x9 SD program to 4x3 letterbox... right?
I would think the hardware (if not the software) should be able to handle that by now.
Floh
by
on Apr 14, 2005 at 4:21:43 pm
[Michael C.] "I would think the hardware (if not the software) should be able to handle that by now."
As far as I know the hardware is capable of doing that. The support for that simply has not been finished in software.
Michael C.
on Apr 14, 2005 at 10:14:57 pm
I think that goes along with the "real-time resizing (and re-positioning)" wish that we've all had for so, so, so long.
Jim Calahan
on Apr 12, 2005 at 1:42:51 pm
We are almost exclusive 16x9 SD as that is what PBS wants is widescreen whether it's HD or not. Your SD recorders are putting a 720x486 signal on tape whether 16x9 or not. 16x9 SD is an anamorphic signal and will have to be stretched for viewing even on a 16x9 monitor so that everything looks normal. When we edit with m100HD we monitor the component output upconverted to HD. HD is true 16x9 and looks great even when we upconvert using the m100HD. We shoot mostly 50mb DVCpro but do get DVcam and miniDV and while they don't up convert as well they look pretty darn good. The m100HD will also convert 4x3 to 16x9 as we do with all our old betaSP material, it basicly blows it up and crops the top and bottom. While this is not the best it looks better to me than what most consumer 16x9 monitors do by stretching only the side portions of the footage leaving the center alone(my wife insists on watching NTSC TV this way at home on our 16x9 monitor). Most home viewers don't like the bars on the sides but will except letterbox as most if not all the networks are showing during primetime NTSC. We send PBS or APT both letterboxed shows and Animorphic 16x9 on DigiBeta which PBS later upconverts and adds 708 captions. I hope that makes some sense, one of the reasons we chose m100HD was the fact it will mix and match formats.
Jim Calahan
KVIE, Sacramento
CameronT
on Apr 20, 2005 at 4:30:25 am
Thank you guys and Floh especially. Finally get to output correctly with letterbox on the 4:3 after updating to version 10.1.1!
