removing series of clips from middle of program
COW Forums : Media 100
Greg
by
on Apr 11, 2005 at 2:09:37 pm
I've got a whole program edited with many unsynched clips. I need to remove about 4 clips from the middle of this 11 minute program. Ordinarily I can just delete the clips and close the gap. This doesn't happen because of all the unsynched clips after these 4 shots. How can I dod this so everything after these shots moves down and closes the gap. Thanks.
Floh
Re: removing series of clips from middle of program
by
on Apr 11, 2005 at 2:24:27 pm
Either delete the clips and choose "Close Gap" (CMD-ALT-G) instead of "Close Gap in Track" (CMD-G). Or delete the clip, move the CTI in the gap and choose "Select from Here" (CMD-ALT-H) and drag everything to the left. "Select from here" is probably the most used shortcut in our company together with zoom in and out on the timeline.
Greg
by
on Apr 11, 2005 at 3:49:01 pm
Hi Floh,
Close gap or select from here in track doesn't always work when there are un-synched clips mixed in. What do you do there?
Floh
by
on Apr 11, 2005 at 3:57:56 pm
Close Gap and Select from Here does work ALWAYS and 100% reliable as they are supposed to work.
Michael C.
on Apr 11, 2005 at 6:19:06 pm
You don't want "select here in track"... you want "Select from here". Command-H.
That will select EVERYTHING to the right of your CTI. You can drag it all over in sync.
Michael C.
on Apr 11, 2005 at 6:21:09 pm
**** E D I T ****
I left out the ALT... Select from here is: ALT-COMMAND-H That's what you want.
Floh
by
on Apr 11, 2005 at 6:22:06 pm
[Michael C.] "You don't want "select here in track"... you want "Select from here". Command-H. "
No, it is CMD-ALT-H. CMD-H is "Select from Here in Track".
Michael C.
on Apr 11, 2005 at 10:01:39 pm
yes... see my edit. ;-)
(I can type faster then I can think)
mhh
by
on Apr 12, 2005 at 9:43:16 am
Have to agree with Greg.
Not always 100% reliable with lots of unsynced clips.
Sometimes the odd one is left out.
Floh
by
on Apr 12, 2005 at 10:21:02 am
[mhh] "Have to agree with Greg. Not always 100% reliable with lots of unsynced clips. Sometimes the odd one is left out"
If you use "Select from Here" every single clip that starts after or on the CTI position will be selected.
