Re-digitizing legacy bins in i
COW Forums : Media 100
Bobby Mosaedi
on Apr 8, 2005 at 7:12:34 am
heres the scenario: i have a bin from many moons ago where clips were logged and dig-ed at 640rez 44.1 and i have the original source tape to redig from except this time i my time line is in 720 48k, when i go to batch digitize all i get is an empty queue with digitize ghosted. If i change media standard to 640x480, thne my clips reappear in the batch dig window. Why cant i force redig in 720? any workarounds? i tried exporting powerlog but only thing i can manipulate is if i want tracks to digitize and the in-out points.
its 2:10AM, i dont feel like relogging all those clips if i dont have to.
Floh
Re: Re-digitizing legacy bins in i
by
on Apr 8, 2005 at 7:20:03 am
You either could export the bin as a PowerLog file and reimport it again, or you can set your hardware settings as you want them to be, select everything in your bin, press CTRL-CMD-ALT-Shift while selecting batch reacuire (hold the keys through the warning messages). CTRL-SHIFT is to force redigitizing of video at the current hardware settings, ALT-COMMAND is for forcing audio to redigitize at current settings.
Btw, you should be able to mix 640 and 720 Media 100 i clips in the same timeline.
Bobby Mosaedi
on Apr 8, 2005 at 6:23:50 pm
Thank you thank you
[Floh] "Btw, you should be able to mix 640 and 720 Media 100 i clips in the same timeline"
btw, floh, i forgot to mention this is on my xs 8.2.2 system. Im assuming that statement refers to 10.0/.1?
Floh
by
on Apr 8, 2005 at 6:29:13 pm
[Bobby Mosaedi] "Im assuming that statement refers to 10.0/.1?"
Yes
