LG 360 spherical videos - how to edit and process for YouTube?
COW Forums : VR (Virtual Reality)/360º Video
<< PREVIOUS   •   VIEW ALL   •   PRINT
brad hebert
on May 26, 2016 at 6:40:30 am
I just got a LG 360. For the price, I am impressed with the quality. However, I'm having trouble editing videos and uploading them to YouTube for proper 360 viewing.
Here is what MediaInfo says about the original video:
General
Complete name : /Users/Cheadle/Desktop/20160525 LG 360 first tests/20160525_224004.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 413 MiB
Duration : 3mn 17s
Overall bit rate : 17.5 Mbps
Performer : LGE
Encoded date : UTC 2016-05-26 02:43:24
Tagged date : UTC 2016-05-26 05:25:28
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L5.0
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=31
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 3mn 17s
Source duration : 3mn 17s
Bit rate : 17.0 Mbps
Width : 2 560 pixels
Height : 1 280 pixels
Display aspect ratio : 2.000
Frame rate mode : Variable
Frame rate : 30.000 fps
Minimum frame rate : 21.845 fps
Maximum frame rate : 30.354 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.173
Stream size : 401 MiB (97%)
Source stream size : 401 MiB (97%)
Title : VideoHandle
Language : English
Tagged date : UTC 2016-05-26 02:43:24
mdhd_Duration : 197683
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 3mn 17s
Bit rate mode : Constant
Bit rate : 512 Kbps
Nominal bit rate : 96.0 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 12.1 MiB (3%)
Title : SoundHandle
Language : English
My export from Premiere is this:
General
Complete name : /Users/Cheadle/Desktop/20160525 LG 360 first tests/20160525 Vads 360.mp4
Format : MPEG-4
Codec ID : M4V
File size : 94.4 MiB
Duration : 2mn 50s
Overall bit rate mode : Variable
Overall bit rate : 4 655 Kbps
Encoded date : UTC 2016-05-26 06:09:07
Tagged date : UTC 2016-05-26 06:09:08
©TIM : 00:00:00:00
©TSC : 30
©TSZ : 1
Video
Format : AVC
Format profile : High@L5.1
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Format settings, GOP : M=1, N=90
Codec ID : avc1
Duration : 2mn 50s
Source duration : 2mn 50s
Bit rate : 4 494 Kbps
Minimum frame rate : 30.000 fps
Maximum frame rate : 30.030 fps
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.046
Stream size : 91.1 MiB (97%)
Source stream size : 91.1 MiB (97%)
Language : English
Tagged date : UTC 2016-05-26 06:09:07
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Color range : Limited
mdhd_Duration : 170133
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 2mn 50s
Bit rate mode : Variable
Bit rate : 157 Kbps
Maximum bit rate : 228 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Stream size : 3.19 MiB (3%)
Source stream size : 3.19 MiB (3%)
Language : English
mdhd_Duration : 170197
I use YouTube's Spatial Media Metadata Tool and then upload. But the video is distorted and not stitched exactly right. This is the top of the video, which should be a straight fluorescent light: http://i.imgur.com/ftKOz7S.png
The sides are doubled where they should be overlapped/stitched: http://i.imgur.com/3Bt70yr.png
I haven't been able to find resources about this. It's way more difficult than it should be to match the Premiere output to the source video.
The LG 360 Android app will share its videos to YouTube, but apparently the videos are not formatted for YT to recognize it as 360.
Any info would be appreciated.
