Is this Possible? Dual Link SDI to 15-pin mini D-sub cable???
jordan82
on Feb 27, 2007 at 5:03:26 am
Is it possible to view a 1080 23.98 fsp image coming out of a Kona2 card (KBox) on a Sony Multiscan E500 CRT monitor? Basically, I'm wondering if (with some adaptor?) one can send Dual-Link SDI over a 15-pin mini D-sub monitor cable. If anybody knows the answer to this, please let me know - thanks!
- Jordan
Bob Zelin
Re: Is this Possible? Dual Link SDI to 15-pin mini D-sub cable???
on Feb 27, 2007 at 5:13:47 am
you mean the CDP-E500
SPEC on this monitor -
Input signals: Analog RGB 0.7 volts peak-to-peak, 75 ohms; separate synch, composite synch, 1 to 5 volts peak-to-peak, TTL, synch-on-green 0.3 volts peak-to-peak, negative
Input connector/cable: Captive 15-pin mini D-sub
It has a VGA input, that takes in RGB with seperate sync - the K Box will feed it sync on green - so the answer is NO.
Get a Dell 2407 if you want a cheap HD monitor that can be used with the K Box.
Bob Zelin
