Deck is in the shop, but still need to monitor
Chris Poisson
on Feb 18, 2007 at 2:15:46 pm
This is a first for me, how do I hook up my LH to my Sony monitor (component) so I can keep working? I have a project to grade today an tomorrow, and I probably won't get the deck back till Tuesday or Wednesday. Can't seem to make it work.
walter biscardi
Re: Deck is in the shop, but still need to monitor
on Feb 18, 2007 at 2:16:28 pm
[Chris Poisson] "This is a first for me, how do I hook up my LH to my Sony monitor (component) so I can keep working?"
Just connect the component output of the LH to your monitor.
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Food Network's "Good Eats"
HD Editorial for "Assignment Earth"
"I reject your reality and substitute my own!" - Adam Savage, Mythbusters
Chris Poisson
on Feb 18, 2007 at 5:16:44 pm
Hey Walter,
That was the first thing I tried, but I'm getting nothing. Is it a control panel issue?
walter biscardi
on Feb 18, 2007 at 5:26:34 pm
[Chris Poisson] "That was the first thing I tried, but I'm getting nothing. Is it a control panel issue?"
Make sure you have the correct format set for the output. If your deck was seeing the output, then your monitor should see it too. Is your monitor set to the Component inputs or were you feeding Composite or S-Video from your deck?
Chris Poisson
on Feb 18, 2007 at 6:20:18 pm
Got it right now, thanks Walter.
