AJA IO and FCPro on Dual Core Mac Pro - crashtastic!
sean@gizmo
on Feb 5, 2007 at 11:23:49 pm
Having an (annoying) issue where opening log and capture window when an AJA easy setup is selected abruptly crashes FCPro. I am completely unable to capture with the AJA right now. Downloaded their 3.0 drivers. Have also discovered that in order to play 10-bit files you have to open Quicktime in Rosetta mode - so there's definitely some issues with the Intel thing going on. it doesn't seem to make a difference with this problem thought. If I switch to DV or any other input it opens no problem. When it tries to communicate with the AJA, however, it dies.
I'm able to output throught the AJA however no problem, FCPro as well as After Effects. Just happens with log and capture window.
Help!!! Thanks.
Bob Zelin
Re: AJA IO and FCPro on Dual Core Mac Pro - crashtastic!
on Feb 6, 2007 at 4:31:21 am
go to the library folder and trash your Final Cut Pro preferences. Restart FCP, and you should be fine.
Bob Zelin
