Analog video output format with Kona 2
Pierre Tremblay
on Jan 29, 2007 at 3:55:28 pm
What is the correct setup for the component analog video output in the
Kona 2 control panel? Component SMPTE/EBU N10 or Component BETA?
What is the difference? I'm monitoring with a Sony PVM-14L2 using
component. My material is for North American broadcast or DVD. I'm
presently using SMPTE/EBU N10.
Pierre Tremblay
JeremyG
Re: Analog video output format with Kona 2
on Jan 29, 2007 at 4:42:30 pm
Are you laying off to Beta at all? If so monitor Beta, if not monitor SMPTE/EBU N10. Make sure your monitor is set up for the same as well.
Jeremy
Pierre Tremblay
on Jan 29, 2007 at 5:04:20 pm
I rarely finish on BETA, always digital. Actually, a post house does
the final broadcast corrections for me since I don't own scopes or
a BETA recorder, only a player. Is the difference in the 7.5 setup?
Pierre
JeremyG
on Jan 29, 2007 at 5:31:18 pm
No, the setup should be added to all analog formats, not just Beta. Beta actually has a SLIGHTLY different color space. You will notice some luminance changes if you switch back and forth between SMPTE and Beta as well.
Jeremy
grassrootsla
on Feb 6, 2007 at 8:58:14 pm
Does the Beta colorspace apply to Digibeta as well? Or just analog Betacam?
