Video Lag coming out of AJA KONA LHe
Threehead Studios
on Jan 28, 2007 at 5:48:31 pm
So Im playing a sequance in FCP (easy setup - AJA LH 525 29.97i 8bit ) Im on a mac pro 2.33ghz with 4 GB of ram.
Once i start playing down my video (which is 29.97i) it plays fine on the FCP canvas, however the video, (on 2 video monitors coming out of both the SDI out, and the component out) starts fine but then slowly falls behind the video on the canvas.
To make it clear if I have a sequence with the numbers 1 through 60 running through it over a minute, at 1 second all monitors show 1, but at around 15 the canvas will show 15 and the other 2 monitors will show 12, and the further it goes the more of lag there is.
Ive triple checked my frame rate.
PLEASE HELP
thank you all
JeremyG
Re: Video Lag coming out of AJA KONA LHe
on Jan 29, 2007 at 2:44:09 am
Have you adjusted you playback offset to zero in the system settings > playback control > frame offset preferences?
Are all of your sequences rendered? What kind of drives and what kind of speed are you getting?
flashcutter
on Dec 13, 2007 at 5:37:26 am
Did you ever get this resolved? I'm having the same problem. Thanks
Gus Falconi
on Jan 4, 2008 at 12:14:28 am
Im having the exact same issue
In overall when playing a sequence in the timeline, using an external monitor, the first second is in sync, then the video starts to slow down a few frames and the audio gets heavily out of sync.
This is only happening in the external monitor. The video in the canvas or viewer is in sync.
I have already installed more than 20 Konas LHe and this is a first.
I already tried the following:
- Updating to Leopard
- Formating my Mac Pro
- Installing/Uninstalling Kona Drivers
- Running software update
- Using a different, cable, breakout box, monitor, DVCPRO Deck,
Thanks in advance for your support.
