Kone Wont see FCP
Lecherro
Kone Wont see FCP
on Jan 22, 2007 at 10:38:04 pm
I know this is a stupid question. My Kona Lhe wont see FCP. It outputs bars to my monitor so i know it is alive. I belive there is one switch or selection in FCP that lets me control wht my kona sees. Any help would be appreciated. and yes I am cross posting this to FCP. Thanks
walter biscardi
Re: Kone Wont see FCP
on Jan 22, 2007 at 11:13:39 pm
[Lecherro] "I know this is a stupid question. My Kona Lhe wont see FCP. It outputs bars to my monitor so i know it is alive."
It works the other way around. FCP sees the Kona.
Be sure you have your Video Output set up to play out through the Kona (Audio / Video Settings) and be sure your External Video is set to All Frames.
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Food Network's "Good Eats"
HD Editorial for "Assignment Earth"
"I reject your reality and substitute my own!" - Adam Savage, Mythbusters
Lecherro
on Jan 22, 2007 at 11:29:34 pm
I found it. I am still getting used to the conversion from Avid. Thank you.
walter biscardi
on Jan 22, 2007 at 11:41:36 pm
[Lecherro] "I found it. I am still getting used to the conversion from Avid. Thank you."
Be sure to read through the Kona manual. The setups are very well explained in there.
